700-R4 Tranny Question Within
Old May 1, 2002 | 08:19 AM
ORAY777's Avatar
How much horsepower and torque can a 700-R4 tranny handle?
I've got the later model version which i think is a little bit stronger than the earlier versions.
Old May 1, 2002 | 05:37 PM
Pro Built Automatics's Avatar
It all depends on what you do to them. Which upgrades?, valve body kit?, etc. I have the parts you need to do this right the first time if you plan on rebuilding it yourself. With the right parts & torque converter it can handle about 525-550 HP max. If you need it to take more then you will need the HD input drum ($250.00), this will give an additional 75-100 HP to the max. rating. I hope this helps some.
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
