Which flywheel size and clutch
Old May 3, 2002 | 02:22 PM
fazool's Avatar
I want to swap a T-5 into my 1986 firebird.
Problem #1, my engine is an early 2-piece rear main seal type. Is there a problem getting a flywheel for this engine? Which size is best? or does the larger 168 tooth flywheel have any clearance problems in the bellhousing?
Problem #2, what clutch to get? Everyone talks about the centerforce. Ok. What other alternatives make sense but are less money?
Any body think of a problem using an 11" clutch setup vs 10.5" setup?
gene
Old May 3, 2002 | 04:03 PM
87RS402's Avatar
If you use the stock bellhousing you can not use a 168 tooth flywheel or 11" clutch, they will not fit. Call a few wrecking yards and ask for a flywheel for a 82-85 camaro, that is a stock GM 153 tooth for a 2pc RMS.
You can also look into McCleod or Ram for a clutch. The correct size is 10.4" (some call it 10.5") 1-1/8" 26 spline input shaft.
Old May 4, 2002 | 05:14 AM
fazool's Avatar
thanks!
I'll keep looking then - a local machine shop had an 11" flywheel for me, but I was skeptical about the size. Glad I asked.
gene
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
Stangski09
Nov 14, 2015 01:27 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
