question about th350
Old May 5, 2002 | 09:17 PM
NJ87CaMaRoZ28's Avatar
I'm just about to buy a th350 for my 87 camaro cause im droppin a 350 engine in it and my friends friend is tellin me it wont fit. He says the bell houseing is too big. No one else said anything about this so i was hopeing someone on here could help me out before its too late...
Old May 5, 2002 | 09:32 PM
ede's Avatar
ede
if it has the SBC bolt pattern it'll bolt up and fit just fine
Old May 9, 2002 | 06:58 PM
bills82z28's Avatar
It will bolt rightup.No problem
Old May 9, 2002 | 08:49 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
it will bolt right up to that bad boy. the only thing that wont is the tranny mount. get the mount kit from summit i think b&m is only 80 bucks
Old May 9, 2002 | 10:14 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
The mount kit from B&M Will only address the TORQUE ARMMM!!!!!! U are going to need a longer driveshaft, a different crossmember & a 3 speed console. All of these parts can be bought from the junkyard. The year of the "PARTS" car U want is 82-84 camaro/firebird with a 3 speed metric 200 trans. When U find the car get the Cross member, driveshaft & 3speed console.
njdaewoo
Old May 9, 2002 | 10:56 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
sorry man i just thought those were already assumed or deamed necessary
Old May 10, 2002 | 01:45 AM
PPonU4Me's Avatar
hey guys, just thought I should throw this out there. I just bolted in a long-tail th350 into my '87 IROC and a diff. driveshaft is not needed, nor is a different mount. The B&M kit addresses all of the above including torgue arm. The only thing is, B&M tells you to buy a new mount for the torque arm, but if you own a drill, you can just drill a couple holes and use your old one. I have no problems what-so-ever with my setup. As far as a different console goes, you don't need one, all the forward gears are just bumped up one gear, i.e. 2=1. 3=2, o/d=3. No big deal as far as I am concerned.
LittleFranks
Sep 17, 2015 12:22 PM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
