will my stock housing hold up to 400+ HP???
Old May 6, 2002 | 06:42 PM
Don_89Iroc's Avatar
i need a rearend that will hold up against at least about 400 hp, i was thinking about keeping my 9 bolt housing, and getting a heavyer duty set of gear's probably 3.42's and also what about my axle's? will they hold up or should i get new one's???
Thanks -Don
P.S. where can i get good set of axle's w/o paying an arm and a leg???
Old May 7, 2002 | 12:56 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
A 9 bolt should hold 400hp. Some guys run more than that through them on the strip. Check with www.moserengineering.com for axles.
Old May 7, 2002 | 08:10 PM
Don_89Iroc's Avatar
thanks for the reply, if anyone is running with close to or over 400 hp on a stock rear or stock rear housing that is a 9 or 10 bolt it would be nice to hear about it Thanks -Don
Old May 7, 2002 | 10:55 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I've been running my completely stock 9 bolt for over 3 years behind my big block (500hp/520lbft) with no problems. I 60ft in the 1.72-1.75 range. I orginally was running a 3.27 gear, but recently went to a 3.73. I am currently in the middle of installing a 4.10 gear with a mini spool in my spare 9 bolt for the track. More information on my setup and on 9 bolt parts is on my page at www.9bolt.com
Miles
Old May 8, 2002 | 01:17 PM
Don_89Iroc's Avatar
one other thing what axes you running in it??? Thanks -Don
Old May 8, 2002 | 05:06 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
I run factory axles, but am going with a set of Moser axles on the mini spool rear end.
Miles
Jeremys87
Jul 14, 2022 09:08 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
sreZ28
Aug 14, 2015 07:48 PM
Vintageracer
Aug 11, 2015 08:13 PM
