Went to race trans stuck. Please help
Old May 12, 2002 | 10:20 AM
BLUEIROC5.7's Avatar
OK all i have a 89 iroc with a 355tpi. My trans is a 700r4 and was rebuilt about a little over a year ago. It only has 17k on it. Well here it is i went to race at the strip last night. I launch and went into second and then the problems started. The car would not go pas 3000 rpm and wouldent shift into 3 so i went down the hole trace in 2nd. The time sex. Well later that night i went to a car show and when i left i stomped on it and i had no problem. If you have any ideas let me know. Thanks ABE
Old May 13, 2002 | 09:04 AM
MdFormula350's Avatar
sounds like maybe some clutches are worn out, i never had a problem with my 700r4 auto tranny, untill i tired to get from drive to over drive, the damn tranny hanged up around 5000 and would not shift i had to left off a chit load to get it to shift. Thats all i can really say about ur problem. I would check your tranny fulid first, u might have too much or too little, check the color and smell, that will be a sign to help u diagnois the problem. Also temperature is a big part in how automatic trannies work.
Old May 13, 2002 | 03:05 PM
Thanks for the help man i will have to check it
Old May 14, 2002 | 05:40 PM
transfixleo's Avatar
It sounds like the Throttle Valve in the VB stuck. This is common and the #1 cause of failure.
AussiePr0nCar
Mar 6, 2020 04:04 PM
theurge
Aug 21, 2015 12:46 PM
Hello, Michael
Aug 20, 2015 03:19 PM
gta power
Aug 13, 2015 06:15 AM
mizz0313
Aug 12, 2015 06:45 AM
