T56 to a 1973 Block?
I was wondering if anyone knows if a T56 will bolt to the block im dropping in my 1990 RS. The block is a 350 that came out of a 1973 Camaro RS. Did they change the bellhousing to block bolts on the Lt1's or are they the same as any other sbc? And will the clutch assembly from a Lt1 work on this block.....just need to know if it will all bolt up.
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I am 90% sure it will work. Don't take my word for it though.
I think you are going to need a special flywheel to go with the two piece rear main seal and the T56.
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
It will work just fine, bolting up isn't the issue. You WILL need an aftermarket flywheel. The bolt patterns on the flywheel from the 1 piece rear main and 2 piece rear main are differant. Centerforce makes one and so does Hayes I believe.
Thanks for the reply guys, now that i know this im gonna go ahead with the T56 install...anyone have any pointers? Also wont i need the clutch assembly out of a T56 car?
topteam54
Oct 6, 2015 12:21 AM
el_muerte
Sep 16, 2015 12:01 AM
mygta87
Sep 14, 2015 10:36 PM
