what gear to get
Old May 12, 2002 | 11:51 PM
speedfreaker's Avatar
what gear to get
i belive {according to the tach article on my yr car} that i have a 3.23 gear ratio in my rear end what would the next step up for more acceleration in each gear be?
basically i want 2nd and 3rd gear to pull as or near as hard as my 1st gear now what ratio should i go to
thank you
Old May 13, 2002 | 03:45 AM
blk91z28's Avatar
3.73s
Old May 13, 2002 | 11:03 AM
ive recently been reading up on this and some guys say the 3.73's are to steep i still need a little driveability on the freeway i just want it to pull up to speed twice as fast maybe the 3.42's
Old May 13, 2002 | 11:13 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
DO NOT get 3:73s if you're running the stock cam. You'll be way out of your power band. That's what happened to me, I didn't gain anything in the 1/4 going from 2:73s to 3:73s, cause the gears keep me out of my power band. 3:42s would work nice, but you already have 3:23s. I don't see it helping that much. I would say do a cam swap and then you can think about 3:73s.
Old May 14, 2002 | 02:59 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
3.42 Richmond gears and Auburn posi are currently being installed in my RS
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
