Is my TC causing this?
Old May 16, 2002 | 01:14 AM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
When I'm running WOT in third and I reach about 80mph the rpm's drop a little and the car starts pulling a lot harder, I have been told that this is my TC locking up, is this true? Would an after market convertor give me this extra pull all of the time?
Old May 16, 2002 | 08:45 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I suppose it's possible. The ECM forces the TC to lock up at around 70-75 mph. That would at least explain the RPM drop.
Old May 16, 2002 | 10:09 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
I had similar problem:
If you think the rpm's drop and pulling are "normal", I suppose is the TC "engaging" the engine with the wheels.
If the rpm's drop and pulling are too much (it was my problem), it can be a bad engine's power and a complete engine's overhaul must be considerated.
Compare with similar cars.
Compare the problem's evolution into next months. It is increased? = bad symptom.
Regards,
Denis V.
Old May 16, 2002 | 04:05 PM
SMKNGTA's Avatar
Car: 1989 GTA
I mean the car starts going faster not pulling from side to side, the engine was about 4000mi on it. At 80mph the rpm's will drop a little and the car starts going faster, so I think it's a good thing.
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
