Changing rear end fluid?? How?
What are the steps in doing this? Any tech articles on it?
What should i replace the fluid with? synthetics? additives?
i have a 9 bolt
thanks
:lala:
i have a 9 bolt
thanks
:lala:
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
take off the cover let it all drain out. make sure you have a new gasket and put the cover back on and torque it down to specs. take out the little plug at the top and pour in the new lube
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
If you have the $$$, buy an aftermarket diff cover with a drain plug built in. Or maybe you could get one machined for less.
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
If you use non-synthetic fluid there is an additive that you're supposed to use as well if you've got posi. I can't remember what it is right now but you should be able to find easy enough.
Car: Sexy
Engine: Stock
Transmission: Slipping
I started a thread on this very thing which started a gasket debate.
I used the gasket with blue sealer. I was told by Miles at www.9bolt.com to torque the bolts to 20-25 foot pounds. I used GM's posi additive and Valvoline 80-90 fluid.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
