What do you guys recommend?
Old May 19, 2002 | 11:09 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I should have my ZZ4 by next summer. With the ZZ4 comes the transmission to rebuild. How do you guys recommend building my 700-R4? What should I put in it to make it strong and a good performer? I don't want to buy a whole new transmission. What about rearend gearing? I was thinking 3:42 Posi. Anything else in the drivetrain that would need beefing up to get the most out of the ZZ4? I plan on replacing the driveshaft with an aluminum one.
Old May 19, 2002 | 11:32 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Get the TransGo Reprogramming kit, this is what the tranny mechanics on this board say to get. "It's the only REAL shift kit".
As far as your gearing, that sounds like a good choice.
Old May 20, 2002 | 09:31 PM
trans87's Avatar
Thanks Mark. I heard that Corvette servos are good as well. Is this true? I am going with the Transgo shift kit because I heard it was the best as well.
Old May 21, 2002 | 02:07 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Get a Pro-Built and forget about rebuilding it
Old May 21, 2002 | 08:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
You'll need a higher stall torque converter as well. Talk to Dana at Pro Built (www.pro-built.net) and he'll get you on the right track for all of this - rebuild kit, reprogramming kit, servo, relief valve, converter, etc.
Old May 22, 2002 | 09:07 PM
trans87's Avatar
Thanks for the responses and showing me a place where to get the supplies.
Wylecoyote08
Nov 6, 2015 03:46 PM
Out-Cast
Aug 22, 2015 07:49 PM
PestilenceIV
Aug 20, 2015 02:33 AM
Street Lethal
Aug 14, 2015 08:25 PM
matthew911
Aug 12, 2015 09:38 AM
