Speedo Gears
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The driven gear is not a problem, 1 bolt from under the car. Pull the unit out, pull off the gear put on the new one reinstall.
The drive gear on the other hand is a major undertaking. You have to pull the trans and disassemble it. (remove the top plate then the back half, and you will see the gear.)
HTH,Don>>>
HTH,Don>>>
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
