Transfixleo
Old May 21, 2002 | 04:55 AM
transfixleo's Avatar
Transfixleo
Hi Gang,
All is well now, Thanks for the support!
Leo
Old May 21, 2002 | 09:37 AM
kevinc's Avatar
Car: 1982 Z28
You're always going to encounter little ankle-biters like that guy, don't feel like they have any real impact on your credibility.
Old May 21, 2002 | 01:14 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I'm curious though, I've seen T.V cables set both ways and have been told either way works well. What are the pro's and cons of both methods?
Tech enough to keep this open for a bit.
:support you virtuial transmission guru!:
TransfixLeo
Old May 21, 2002 | 02:52 PM
Well esentially they are trying to do the same thing and in many cases you wouldn't notice a difference. Where you do see it is if you pay close attention when following the steps. I always find that when you check the throttle to see if it is indeed at WOT that it is not. If you follow the standard factory method you will not do anything about this and it will always be out of sync, plus you are losing that slight bit of WOT action on the motor. Now it only takes a minute extra to do it my way and you correct all of those little problems first time.
ajh87iroc
May 15, 2009 08:51 AM
ChevyLuva3
Feb 5, 2002 07:46 AM
b92z28
Dec 12, 2001 04:37 AM
Dyno Don
Nov 2, 2001 04:10 PM
Eddie
Jun 15, 2001 04:46 PM
