700R-4 in place of T-5
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
I need to know if swapping a 700R-4 trans from an 88 GTA into an 87 GTA originally equipped with a T-5 will work. I know the trans will fit, but what I need to know about is the computer change. It's my dad's car and we've tried putting an auto trans prom into the 87 while the T-5 was still alive and the car wouldn't turn over. Now that the T-5's dead we've decided to go with the 700. I need to know if I can just transfer the 88 computer over to 87 along with auto prom and will it run, since the 87 computer with the 88 chip didn't?
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If both cars are TPI the computers are the same. You can verify this by checking the service #s on the ECMs. If they are the same then just swap the PROMs.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
It wouldn't start probably cuz the ECM didn't know the car was in park. Need to wire up the Park/Neutral Safety switch, or bypass it all together.
Pac J
May 17, 2020 10:44 AM
