GM part 8673948 WOT 4th gear and 700r4
Old May 29, 2002 | 02:13 PM
Slade1's Avatar
Basically I got the kit which allows WOT in 4th gear and I want to install it. The only prob is this is a a daily drive car for me. Now I plan on doing this myself since all the mechanics in my area either a) have not heard about such a mod or b) want to milk me for all my cash and bs me with it'll take 5 hrs to put in but I'll charge you 10 since you know squat about autos. The kit comes with a tv boost valve, a modified kickdown valve with spring and housing a gasket and 2 paper things which could probably be gaskets too. Before I commit and get the filter and fluid, I want to know as much as possible before I get into the transmission. So I figure I'd tap you guys who have a clue, have gotten into the tranny or have done the mod. If you did it with the b&m kit, its the same thing so your experience is welcome. I know the valve body must come off but that's about all I know.
some questions... and please be as detailed as possible
Estimated time for this job?
Should I take out what needs to be modified or do I have to work on it there?
Where does the TV boost valve go?
Which valve is the 4th gear valve?
Where do the paper gaskets 1 with red line and many holes and 1 with 2 yellow lines and many holes fit in?
Thanks for any help
Old May 29, 2002 | 04:29 PM
Pro Built Automatics's Avatar
Take a picture & put it up so I can see exactly what you have and what it will take to do this.
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
dhonda200
Aug 11, 2015 11:50 PM
1nastygta
Aug 8, 2015 07:38 PM
