guys everyone with a cure for vibes
Old May 29, 2002 | 10:29 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i'm having vibrations and it's pissing me off, i need to figure out whats going on, a little history first, vibration did not exist when 160k miles on clutch/engine/tranny, pulled tranny for a clutch change, installed new flywheel/clutch/pilot bearing rebuilt transmission, new bearings, new slider gear and synchros, new u-joints installed on driveshaft, now i have a vibration at 60-80mph is the worst faster and its still there but not as bad, sounds like a bent fan blade, push in the clutch and it goes away, if you vary the throttle on and off while vibrating it seems to have an affect on it, so i pulled the driveshaft out and installed a different shaft same thing, things i tried/checked.
rotate driveshaft 180 degrees
checked transmission mount
checked ext housing bushing, very very little side to side movement with yoke installed
rear was just re done with new axles/posi/gears/bearings, vibration existed before and after
there is no vibration through the rpms while in nuetral, you can redline 1st, no vibrations
i dont get it....
it's a 1986 305 / T5 /3.73 combo with steel driveshaft.
Old May 29, 2002 | 11:02 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It has to be be something with the tranny.
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
