mixing ring and pinions?
Old Jun 1, 2002 | 12:43 AM
Lowaholic's Avatar
hey all- does anyone know if you can mix a ring gear from one set and a pinion from a different set? Like if you needed a specific ratio for a certain application and nobody offered that exact ratio, could you just use any ring and any pinion with the necessary teeth counts? ie- if a 4.10 is 41 ring and 10 pinion teeth and a 3.23 is 42 ring and 13 pinion teeth, can you use the 42 ring and 10 pinion together to get 4.20? Well thanx for any ideas
Old Jun 1, 2002 | 01:19 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
No, you can not mix ring and pinions, not even within the same ratio.
Miles
Diff Solutions
Old Jun 2, 2002 | 12:26 PM
Lowaholic's Avatar
alright, next question then- does anybody know if any companies or shops make custom ratios for gm 7.625" or 8.5" rears other than the usual ones (ie- 3.42, 3.73, 4.10, 4.56, etc)? This is for my full-time AWD S-10 and I'm trying to mix 17" wheels front and 18"s rear (sorry not necessarily f-body related, but nobody on any of the other boards had any ideas). Anyways I know I could just put smaller tires on the back so they're all the same size, but what fun would that be? Hopefully I'd like to stay somewhere around 235/40/17s front and 255/35/18 rear and the front diff ratios are limited to (as far as I know)- 3.42, 3.73, 4.11 and I've been told 4.56 but never seen those personally. The rear is the stock 7 5/8" but I could change to an 8.5" if I need to. Well thanx again for any ideas
ps- actually if anybody knows where to get odd ratio sets for the 4wd S- truck front 7.25" diff I'd definitely check that out too
Old Jun 2, 2002 | 04:23 PM
ede's Avatar
ede
there is no suck thing as a custom made gear set, there are only a limited number of ratios that would work, or be pratical. notice that all gear set teeth count are prime numbers? it's done for a reason. i guess you could come up with a combination that isn't made but i doubt if it'd be worth it or reasonable to make.
Old Jun 4, 2002 | 10:31 AM
Beefy89's Avatar
The ring and pinion are lapped to mate each other.So say you and your buddy each have the same 10 bolt rear end with 3.42:1 gears.You can't use his ring or pinion because they weren't lapped to mate each other...
Hope that makes sense........
Old Jun 4, 2002 | 10:15 PM
RICHRAD's Avatar
Yea, There is a special set of 3.70's out there (10 bolt 7.5). I think they have 7 teeth on the pinion and 26 on the ring. Something close to that. I've seen'em on Ebay a few times...look beefy
LT1Formula
Oct 8, 2015 08:34 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
gord327
Sep 29, 2015 10:18 PM
