Kickdown Cable install Help
Old Jun 3, 2002 | 01:46 PM
Zuckuss88GTA's Avatar
OK i just bought a new kick down cable for my tci 700r4. There is one on right no but it is no good. I bought a B&M kick down cable and i am just wondering how would i go about changing it? I think that the other is still conected but to where? i think inside tranny? Any help would be great
87' T-bird (soon to be donated)
90' Dodge Shadow (work car)
88' GTA (Project car)
Old Jun 3, 2002 | 02:04 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Remove the small 10mm hex head bolt that holds the cable to the trans. Pull the cable out. It is attached by a wire bent into a hook to the eyelet on the end of the cable. To install pull the wire up from the trans & hook through the eyelet. Have someone pull on the engine end of the cable slightly to keep it hooked while you push it back into the trans. Reinstall 10mm bolt. It can be a real PITA because of tight quarters.
Old Jun 3, 2002 | 02:19 PM
Thanx alot! Looking forward to getting started after work
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
