how do i hook nuetral safety switch up on bm mega shifter??
Old Jun 10, 2002 | 02:18 AM
2ponchos's Avatar
i have the console shifter in my 88 bird i hooked the relay up like they told me to but last year wheni put it in i could never get the safety switch to work properly. the car starts in every gear. i wana start doing some racing for money at the track and to pass tech i need to have it hooked up its been so long since i wired it i cant find my directions that came with the shifter and i need to hook it up asap so i can pass tech any help would be great thanks
Attached Thumbnails how do i hook nuetral safety switch up on bm mega shifter??-2ndwash_0006.jpg
Old Jun 10, 2002 | 12:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd suggest giving them a call 1-818-882-6422.
Sounds like your switch is either shorted, or the wiring wasn't done quite right.
Old Jun 11, 2002 | 04:13 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
i just intalled one in my car but i also have alot of experiance in wiring (grandfather is a tv repair man)
i put mine in and it worked great
they say that you have to adjust the switches so it will only switch on when it is in park or nutrel
i would loosen the screws that hold the switchs in place and move them way a very little bit from the shifter and see if this helps any
Old Jun 13, 2002 | 07:02 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
ill email you the instructions
Old Jun 13, 2002 | 10:33 AM
2ponchos's Avatar
thanks for the instructions !!!!
Old Jun 13, 2002 | 12:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree with the "switch alignment" idea. Plus, with those microswitches, you can actually bend the metal "lever" of the switch (be careful, use two pair of needle nose pliers on the lever ONLY, so you don't ruin the inside of the switch).
Old Jun 13, 2002 | 02:00 PM
2ponchos's Avatar
i remember i had to jumper a wire to get the dang car to start buit when i did that it started in all gears i just wana make it right now so i can bracket race i just could never figure out what was wrong. thats why i jumpered it to make it work
Old Jun 14, 2002 | 05:15 AM
Engine: 406
Your welcome, Now how about you come on down and install mine for me... ..
Old Jun 14, 2002 | 01:31 PM
2ponchos's Avatar
maybe i should then i could figure out where i went wrong lol!! good luck its not that hard to install obviously the hardest part for me was the wiring and i am still trying to figure that out
Old Jun 15, 2002 | 06:20 AM
Engine: 406
The hardest part for me has been getting my lazy a** off the couch and getting it done. Guess I shouldn't have bought this new Big Screen TV....
GTAman
Jul 3, 2024 07:29 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
