T5 manual conversion
hi guys,
i am gonna be taking the T5 out of my mustang shortly and had a question. my cousin, see the sig, is always complaining about not having a manual. I heard from some site (i think that its this one) that the mustang T5 will work in camaros without any hastle. sure, he will have to get the flywheel, clutch, pedals and other accessories...but is it true that they are a compatable swap?
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm pretty sure the case is completely different too. The GM T5 mounts up to the bellhousing at an angle, and the Mustang unit is straight.I don't think it's a feesable swap.
-Rich-
-Rich-
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
You say your cousin has a 350? Im pretty sure that they didn't put T-5s with the L98 Engines because they cannot handle the torque of them. Maybe Ford's T-5s are (Cough) stronger, but I am pretty sure that T-5's will die when linked to a 350. Just another factor to consider.
Car: 1991 T-Top RS
Engine: 305 TBI
I have a friend running a 350 on a T-5 and it's running perfectly fine for the last year. I'm also doing this swap on Friday. As far as the Ford working in chevy no. THey mount at different angles. Sorry Charlie!
