Driveline Whine
Subscribe
Jun 17, 2002 | 06:19 AM
I have a whine in my driveline. It is only when power is applied, coasting its quiet. I have:
9" Moser rear
custom built 3.5" driveshaft
Raptor 700R4 (did the same thing with old trans)
Spohn Torque arm & crossmember
I have done:
pulled 3rd member & rechecked gear pattern on ring & pinion
checked driveline angles +2 deg diff. @ trans & -2 degs diff. @ rear
Replaced rear u-joint
I'm perplexed. Any ideas ?
Reply 0
Jun 17, 2002 | 03:10 PM
Maybe it's an axle bearing ?
Reply 0
Jun 18, 2002 | 05:49 AM
Wouldn't a wheel bearing make noise anytime the wheel was turning, not only under power ?
Reply 0
Subscribe
