Corvette 700R4 fit a Camaro?
Old Jun 17, 2002 | 02:57 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
My neighbor ordered an Art Carr 700R4 transmission. They screwed up the order and sent a Corvette tranny. Can he just swap tail housings and use it or are the output shafts differant length?
He called Art Carr and is getting two differant answers from the sales people. One yes and one no. WTF?
Old Jun 17, 2002 | 04:51 PM
nsimmons's Avatar
hey should be able to, my buddy is running a camaro tranny in his vette.
He should consider himself lucky, then vette tranny is a better unit
Old Jun 17, 2002 | 05:37 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
How exactly is it better? If it's an art carr built transmission, I'm sure everything inside is aftermarket stuff anyway.
Old Jun 17, 2002 | 05:45 PM
nsimmons's Avatar
well thats what i was thinking. Its a completely after market tranny with just a different tailshaft their vette and camaro version are probably the same.
If they are based on specific fbody-vette trannies, then the fbody tranny would lack the ability to go wot in 4th and shift to 4th at wot, but I sure these issues have been resolved which ever tranny you bought from them.
I would guess the only difference is the tail shafts.
Old Jun 19, 2002 | 09:26 PM
Lionsden's Avatar
TCI says is won't work, well at least that the tail shaft is a different length.
700-R4 4L60 (4L60E 1993-1995) (bellhousing pattern - Chevrolet)
Corvette A = 29 7/8
(84-96)
All others A = 30 ¾
http://www.tciauto.com/tech_info/trans_dims.htm
Old Jun 19, 2002 | 09:31 PM
nsimmons's Avatar
dan, but wouldnt you get the necessary length if you installed a camaro tail shaft?
Old Jun 19, 2002 | 10:21 PM
Engine: 4.0L
Dan, thanks for the link. That's exactly what I was looking for.
nsimmons, who wants to pay out the a$$ for an Art Carr tranny and go ripping it all the way apart to change the output shaft? It would also void the warrenty.
Just changing the tail housing won't work according to Dan's link.
Old Jun 19, 2002 | 11:25 PM
Pro Built Automatics's Avatar
The Corvette tail section is shorter, and so is the output shaft (apx. .950" shorter). Most Corvette's do not have the bolt holes for the transmission mount in the case. The Corvette uses the tail section as the place to bolt the mount. I am not impressed with the Art Carr 700R4 transmission, as I have torn down many, and their lack of quality and bad materials, poor workmanship, etc, says you are paying for the name and not much else.
Frozer!!!
Jan 19, 2024 04:55 PM
kah992
Aug 19, 2015 02:55 PM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
