Drive Shaft
Drive Shaft
I am looking to find out how to disconnect the drive shaft on a 1982 Firebird V6 for hauling purposes. I am using a car dolly and the back wheels will be on the ground. Thanks for all of your help.
Brad
Brad
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Just loosen the (4) 7/16" bolts on the differential yoke at the end of the shaft and pull the u-joint out. Then tie it up somewhere and away you go. You could use some of that 100 MPH tape, too. That'll hold it in place.
Ed
Ed
Transmission: 4L80E/4L80E
Make sure you use some of that tape around the u-joint caps. If not, you'll arrive with a cap or two missing, and your next stop will be the parts store for a new u-joint.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Ozz1967
Aug 16, 2015 10:23 PM
