what evidence do we have that Dynamic compression ratio is valid?
Old Jun 21, 2002 | 04:10 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
http://cochise.uia.net/pkelley2/
some stuff from vizard i think
This is a useful little VBasic program I wrote to calculate Dynamic Compression Ratios (DCR). Knowing the DCR is very useful for cam selection, since compression in the cylinder cannot start until the intake valve is closed. Knowing the remaining amount of crank stroke left after the intake valve is closed is needed to calculate the DCR. According To David Vizard, a street engine running on pump gas should have around 7.5:1 DCR, a race engine should shoot for 9:1. These ratios will produce the best torque output. All these calculations must be done with seat timings. Since compression doesn't start until the intake valve closes, using .050" tappet lift gives an incorrect result. At .050" the valve is still open .050" times the rocker ratio. In the case of a SBC, the valve is still open .075" (that's around twice what a plug is gapped at) and a BBC's intake valve is open .085". That's a big leak as far as compression is concerned.
The DCR Calculator provides three separate calculators. One for calculating the valve closing points, another for calculating the remaining stroke length after the intake valve closing, and a third for calculating compression ratios. There are various way the DCR Calculator can be used.
If you don't know the valve event times, use the "Cam Timing and Overlap Calculator." Enter the advertised duration for both the intake and exhaust, the Lobe Separation Angle, and the installed Intake Lobe Centerline Angle. The calculator will return the valve events for that cam.
Next, enter the results along with the rod length and crank stroke for your engine in the "Dynamic Stroke Length Calculator." This calculator returns the amount of the crank stroke remaining after the intake closes. This is the Dynamic Stroke Length (DSL). The distance the piston is from BDC is also shown.
After getting the DSL, go to the "Compression Ratio Calculator." Enter the required information using the DSL for the "Stroke" input. The calculator returns the Compression Ratio for that combo, in this case the Dynamic CR. You can also use the crank stroke to get the Static CR.
Where this info is most helpful is in selecting a cam and setting the proper CR. Since a pump gas engine wants around 7.5:1 CR, you can work with the chamber size and piston dome/dish to get this for a chosen cam. Going the other way, if you already have the heads and pistons, it is easy to try different cams to find one that give the desired results. Of course, this works for race engines, too. Just shoot for 9:1 DCR.
After getting the DCR where you want it, enter the crank stroke to find out what the static CR needs to be. Order the parts accordingly. As for the cam, the intake lobe center, and LSA don't really matter as far as the DCR goes. The only thing that affects the DCR is the intake closing time. Get a cam with the correct intake closing point and you will have the desired dynamic CR. The rest of the specs are up to you.
David Vizard never specifies if these numbers, 7.5 and 9:1, are for iron or aluminum heads. Since almost all he talks about in his books are iron heads, I'm assuming these numbers are for iron. I know of a fellow running at 8.12 DCR with aluminum heads and 92 octane without any problems. It appears that aluminum heads can tolerate (and probably need, due to thermal loss) another 1/2 point of DCR.
This is my first Visual Basic program. I got some help from a friend of mine, Blair Legate, on the coding for the "Dynamic Stroke Calculator" module. I did the design of the interface and wrote the code for the remaining modules. The CR calculator formula was written by Ray Forceno and adapted to this program by me. I hope it proves useful.
Old Jun 24, 2002 | 08:29 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
sorry.. wrong forum.. I wondered why I could not find it later
. I will repost in engines.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
