700R4 or TH350?
700R4 or TH350?
I have a '78 TH350 and am getting a 700R4 from a 92 Iroc. Which tranny is going to be better? I currently have the stock 2.27? rear gears which I am swapping out with 3.42 if I use the 700R4.
If the 350 is a better tranny what gearing should I look into, to get about the same perfromance out of it? This is mostly a weekend driver and will be at the track on occasion as well.
I have heard that the 700R4 that I am getting is a really good tranny and it has been recomended that I install that instead of the TH350.
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Re: 700R4 or TH350?
The 350 can handle more hp in its stock form but if you aren't topping 350 hp then the 700r4 is fine.
I can't make out what your current rear gears are. If they are 2.73s then go ahead and change to the 3.42s. But if you have 3.23s or 3.27s it is a waste of money to switch to the 3.42s. They are just too close to see a difference for the money.
Its the torque that will kill a tranny, and the TH700R4 will take up to 450ft-lbs in stock form.
Forget about the TH350. It's a different length and will just be a hassle to install when the OD tranny will be your better choice anyway.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
