Borg Warner T-5 shift pattern?
Old Jun 24, 2002 | 08:37 PM
Adam944's Avatar
What is the shift pattern for the T-5 Borg Warner manual trans? Reverse seems to be where first usually is.
Thanx.
Old Jun 24, 2002 | 10:10 PM
89_RS_Mike's Avatar
2 4 R
There you go
Old Jun 25, 2002 | 12:05 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
If reverse is where 1st usually is, then it's probably not a T5.
Old Jun 25, 2002 | 08:07 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Unless you have it installed BACKWARDS.
Old Jun 25, 2002 | 08:19 AM
PonchoTA's Avatar
Are you sure you don't have the 4 speed out of an '82? They came with the older style transmission (Super T-10) with external linkage rods (as opposed to internal rail type T5) Those transmissions had reverse "left and up", the T5 is "right and down"
Even if you have a 5 speed, look to see if you have linkage rods on the left side of the case. If it IS a 5 speed, it's probably a Richmond or Doug Nash 5 speed. IT'S CRAP!!! GIVE IT TO ME, I'LL TAKE CARE OF IT FOR YOU!!
Hope this helps...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
