700R4 - How much ATF?
Old Jun 25, 2002 | 12:42 PM
KeithO's Avatar
I am going to replace my broken 700R4. I want Red Line ATF to put into it. I am not sure how much ATF to get for my mechanic.
Here are the capacities that I was told:
Chiltons - 10 pints (2.5 quarts?)
Haynes - 4.7 quarts
Both of these seem low to me. I already have 7 quarts of Red Line.
Riddle: How many quarts of Red Line are required for a complete fill for a replacement tranny?
Old Jun 25, 2002 | 02:49 PM
Joshua Leslie's Avatar
those manuals are proly stating how much a refill is if only changing the pan.
sometimes a tranny will come with fluid already in the torque converter, or at least a quart or 2 in there.
so flip it upside down and see if any pours out.
if the tranny is already in the car, dump 5 quarts, start it up, let it run for a minute, check fluid.
an empty tranny will hold about 10 quarts or so.
Old Jun 25, 2002 | 05:53 PM
KeithO's Avatar
Thanks. Just to be safe (and to possibly have some extra on hand), I should order another 6 quarts and that should cover me. Thanks again.
Old Jun 25, 2002 | 09:49 PM
RICHRAD's Avatar
Why Redline brand fluid....Should I put this back in my trans during a shift kit install?
Old Jun 26, 2002 | 05:48 AM
KeithO's Avatar
Though opinions vary, Red Line is the "Mobil 1" of tranny fluid. There are alternatives like B&M Trick Shift, but ALL of the amateur racers that I know (and that's alot) exclusively use Red Line for their fluid fills (tranny fluid, rear fluid, coolant addtitive, etc). I am converting my IROC, item by item, to Red Line products.
For product descriptions, try www.redlineoil.com I have already changed over my rear end.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
