T-56 and Lt1 swap.......... got questions.
Old Jun 27, 2002 | 12:22 AM
Four12'sCamaro's Avatar
I pulled my 305 and 700R4 and now am dropin a lt1 and T-56 6 speed in its place , am i gonna have any problems? Are the driveshafts the same length? i have all parts possible, it was pulled from a 95 camaro. Will the whole 6 speed part have any problems with fitting in a stock manual tranny shift plate? Let me know if you have done this and have come across any problems. Thanks!
Old Jun 28, 2002 | 02:37 PM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
The only problems you will have are:
1. Custom Trans Crossmember
2. Rewiring reverse Lights, Neutral safety switch, and Reverse Lockout.
3. Mounting the clutch master cylinder.
4. Interfacing all of the electronics to get your gauges to work correctly.
But, the shifter will stick out of the stock location just fine. The stock driveshaft will fit perfectly.
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
