which would be the better way to go
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
take my stock 82, 26 spline rear and rebuild it, put a posi in it and gears, i dont know where to get a 26 spline posi unit, any reccomendations?
or buy a 28 spline rear $40-50, 89-92 right? put a slp diff in it, $100 and a new gear set in it $200. oh by the way how much would all this stuff cost, with me installing it, my guess would be 350-400? thanks
good axles 120 each
gear set 200
install kit 100
slp posi 100
girddle 150
and several hundred dollars worth of tools if you don't already have them, depth mike, 0-1 mike, indicator and base, in/lbs dial type torque wrench, and something to hold the yoke. a press and bearing seperator is nice to have but you can farm that out if you have to.
gear set 200
install kit 100
slp posi 100
girddle 150
