Engine knock seems to be coming from flywheel.
Old Jul 4, 2002 | 08:51 PM
MrsLottaBallsCamaro's Avatar
First off, its a 91 RS with a 305 and a T5. It has a very loud knok that vary directly with the RPM. I pulled the flywheel cover and it serioiusly sounds like its coming from the clutch or flywheel. The noise doesnt change when you disengage the clutch though, any ideas???
Old Jul 5, 2002 | 02:32 PM
ede's Avatar
ede
i'd get a stethscope and start sticking it on parts to locate the sound.
Old Jul 7, 2002 | 10:11 AM
racerx004's Avatar
I had a similiar problem once.
Check the thowout bearing. My 84 z-28 had something like happen.
I couldn't tell untill the mechanic put it on a lift and engaged it from underneath.
Old Jul 9, 2002 | 02:59 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A header collector leak can sound a lot like a rod bearing or a cracked flywheel.
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
