Makein my gears possie
Old Jul 7, 2002 | 08:41 PM
Crazy2.8V6Man's Avatar
I was wonderin if thear is any way to make my gears that i have in my car possie like by welding the gears togeather.
Old Jul 7, 2002 | 09:19 PM
32789RS's Avatar
You can weld the rearend to make it a posi, but I would not do this, just for the simple that when the weld brakes and if you put any serious amount of power to it, it will, then you have peices of metal floating in your rearend and this can destroy your rearend. I would just go out and get a posi unit. I have had good luck with Auburn posi units, they can be a bit pricey though. You could also go to the local junk yard and get a rearend that is already complete with a posi. Just a few ideas.
Old Jul 8, 2002 | 11:13 AM
so a stock 350 would tear up the wealds. How much is a unit at a junkyard ball park figure.
Old Jul 8, 2002 | 12:58 PM
32789RS's Avatar
A stock 350 would proably be ok, around here posi units go fo any where from $50- $100 if you pull it.
Old Jul 8, 2002 | 07:20 PM
FirstShot002's Avatar
Go to powertrax.com. Quick and easy
Old Jul 10, 2002 | 04:41 PM
Fast3rdGen's Avatar
replace the spider gears with a mini spool. thats what i did in both my old 10 bolt and my ford 9".
Old Jul 10, 2002 | 05:03 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Dude, isn't a possie like a group of thugs that you hang out with? I think you may be referring to posi-traction. If you buy a spool, expect to break things or chew up tires. Get yourself a complete "possie" rearend from a junk yard. Look for a little aluminum tag that says "Limited Slip Differential Fluid Only" . It will be on the diff cover. I paid $65 for one.
You will then need to remove the old diff in your car, remove the old ring gear, bolt the old ring gear on the "possie" differential, and re-install. It's just that easy!
Old Jul 11, 2002 | 11:42 AM
OK sry i cant spell worth a ****
Old Jul 11, 2002 | 01:50 PM
ede's Avatar
ede
if anyones interested i have a new unused mini spool for a 7.5 26 spline rear i'd sell for 75 dollars shipping included
Old Jul 11, 2002 | 06:31 PM
EDE. EMAIL ME at ICEMANN002 @AOL.COM I am interested in the mini spool. Thanks
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
