What stall for my 700R4 (lockup/nonlockup??) Help
Old Jul 8, 2002 | 05:19 PM
gtabadboy's Avatar
I am having an engine built for my car and need a stall to match. I need one that is from 3500-3800 but I also plan on running 300HP nitrous boost. I am putting in 4:11 gears and my new engine specs are in the signature. Where can I get a stall for this application? What brand? Do I need a custom one because of the torque from the nitrous? Is it a lockup or nonlockup? Part numbers would be great? Thanks in advance!!
Old Jul 9, 2002 | 02:21 PM
Pro Built Automatics's Avatar
Depending on the size of the cam at .050 lift?, what transmission you are using?, Is it built to handle 600- 700 HP?. Do you want or can you have a lockup TC. These things are part of what determines the stall you want/need. Let me know?
Old Jul 10, 2002 | 08:19 AM
gtabadboy's Avatar
Cam calls for a converter from 3500-3800 Dur @ .050 is 248/252 Its a roller lunati cam. Lift is .606/.585 and I have a 700R4 tranny. Plan on running 300HP nitrous also.
Old Jul 10, 2002 | 04:03 PM
If you are going to use this much nitrous, then I would keep the stall down to around 3,200 rpm. What are the lobe centers on this cam? Let me know?
HoosierinWA
Oct 7, 2015 10:15 AM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
