El Camino Rear Posi?
I found a posi rear end from a mid 80's El Camino that is presently a 2.43 ratio. I am looking for a 3.08. I was wondering if I could swap the ring and pinion on them?
It is a 7.5" unit.
It is a 7.5" unit.
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I think that is a different series carrier, called a "2 series" carrier. You will need to buy a spacer shim or a ring made to adapt a 2 series carrier to a 3 series gear.
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
