Rearend maintinence
Old Jul 9, 2002 | 11:24 AM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
Rearend maintinence
I've got an '89 IROC-Z with the Borg-Warner 2.77 limited-slip rearend. The car has been up on stands for a while for a rebuild, and I've noticed that the rearend has leaked, although it's not too obvious from where. The weird thing to me is that the whole cover plate is covered with fluid. This car hasn't been driven for a few months, so you'd think it'd just leak down, but it almost looks like it came out with pressure from the fluid plug (the the big round thing in the middle). I haven't found any fluid on the ground. Also, it seems like there is a high-pitched squeak comming from the input shaft on the rearend (where the driveshaft hooks up) when I turn it.
Is this a common thing to happen? What do I need to do about it--use a gasket or sealant? Also, I understand that parts are hard to find for Borg-Warner rearends, so if I need something that I can't get at an Autozone or O'Reilly, where should I go?
Also, last thing... What kind of lubricant do I need to be using on this thing? I can remember reading somewhere that you're supposed to use a special lubricant with an additive...
Old Jul 9, 2002 | 03:09 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Looks like you need a new rear cover gasket and a rubber plug (red or black). Everything else you need (parts and information) for a 9 bolt is at www.9bolt.com
Miles
Diff Solutions
www.9bolt.com
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
