26 spline to 28 swap
Old Jul 21, 2002 | 02:57 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
I was just browsing threw some msg's and i assume that i have the 26 spline axles in my '86. Would i be able to upgrade to the 28s without having to do any messy gear work or anything like that?
Old Jul 21, 2002 | 04:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
you need a carrier (or at least the side gears) and axles. I don't know what you'd consider "messy"... personally anything i have to do laying under the car is messy to me You don't have to change the pinion gear or even disturb its bearings though, so i suppose in that respect it's not too messy
Old Jul 21, 2002 | 06:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You'll probably need the new carrier. I tryed swapping some 28 spline aftermarket axles into an 86 diff with 28 spline side gears and the axles wouldn't fit through the hole in the carrier. 1 1/6" drill bit fixed the problem.
hectre13
Dec 11, 2023 08:14 AM
Genopsyde
Oct 7, 2015 08:35 PM
draco
Oct 4, 2015 09:25 PM
Irocguy01
Sep 28, 2015 02:03 PM
Eric-86sc
Aug 24, 2015 09:01 PM
