Can someone identify this rear end?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Those numbers mean nothing. You need something like CB G 112 1 E
Sounds like a part number. Try calling GM
Car: 4
Engine: 6
Transmission: 5
What do you want to know about it?
Count the cover bolts, it's either 9 or 10; that will tell you if it's either a 9- or a 10-bolt. Then take the cover off and look at the gears, they will have their ratio stamped on the edge of the ring gear. Then look inside the carrier and see if there are clutches; if there are, it's a posi, if not, it's not.
Don't waste your time trying to ID a rear end by any other means, they are notoriously unreliable.
Take off the cover and look!!!! If you haven't changed the fluid lately, you need to pop it off anyway. Just go ahead and do it.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
