SGI-5 hook up question
Old Jul 27, 2002 | 03:47 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I've did a search, and could only find T-56 and aftermarket speedo questions.
I just had 3.73s installed not to long ago and need to recalibrate the signal.
Here's how I've tried hooking it up-please let me know if this is totally incorrect. I spliced into the "A10" brown wire comming off of the ECM to pick up the VSS signal.
12v source------------to--DD PWR terminal
ground-----------------to--DD GND terminal
VSS signal-------------to--DD Sig IN
Out 1/Out 2-----------to--ECM
I'm using the application #2 chart.
My speedo reads the same as before I tried using the box, and I've played with the calibration table settings as well.
Any help would be appreciated. Thank you, Roy
Old Jul 27, 2002 | 11:17 PM
Engine: LO3;383tpi
anyone????
Old Jul 28, 2002 | 07:28 PM
jimbuck's Avatar
I had the same problems. I would have to go look, but I think I ended up using different outs.
Jim Buckingham
deracer
Apr 11, 2016 12:04 AM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
