TH350 vacuum?
Old Jul 29, 2002 | 07:17 PM
Cuno's Avatar
TH350 vacuum?
I am installing a TH350. The question I have, is where should I connect the vacuum line? The carb? Another question is does the vacuum determine the shift points on this tranny? If so, is there a way to modify the shift points if I need to?
Old Jul 29, 2002 | 07:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It needs to go to manifold vacuum. You modify the shift points with the vacuum modulator. You'll need an adjustable one.
Old Jul 29, 2002 | 10:46 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Stephen, do you know of anyone that's had luck with adjustable module. I've only seen the one on my friends chevelle and it just plain doesn't work-screwed in or out, nothing changes. It'd be great for bracket racing if it did though.
Old Jul 29, 2002 | 10:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
When I used a TH350 I never used a modulator valve. I doubt you could get it to shift at the same place every time. I manually shifted each gear.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
89newfun
Sep 16, 2015 09:28 AM
