Filter seal question
Car: 1991 Firebird
Engine: 383 stroker
I've been having problem with my new (rebuilt) tranny and today I went to put a new filter in. The old seal (actually pretty new) didn't come out with the old filter (also pretty new), so I pull it out and throw it away and then I lube up the new filter and seal and start to put it in but it didn't feel like it was going in easy enough so I pulled it back out and there was another seal on the end of it that was a black color. I've never seen one that was black, so I figure that it may have turned black over time or maybe from the trans being over heated once before in the past before I bought it and it just never got replaced. I understand that 2 seals can cause the tranny to suck air or something to that effect? I'm 99% sure that it isn't something that is supposed to be there but can someone make me 110% sure?
Thanks,
Tom
Thanks,
Tom
yep only one seal and all of the filters i ever took out the old seal stayed in the valve body. you have to dig and pry to get them out. i use a soft hammer and gentley tap the filter in place so the seal seats and the filter seats on the seal.
Car: 1991 Firebird
Engine: 383 stroker
Well I got the seal situation taken care of and but now the drain plug that I installed wont clear the filter
So word to the wise, don't put your drain plug in the front center portion of the pan.
So word to the wise, don't put your drain plug in the front center portion of the pan. Thread
1992 Trans Am
May 10, 2023 07:19 PM
