ID and buildup info..
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I'm thinking of building up a modded 350 and I wanted to know of a way of knowing what transmission I have. It's an auto, and I want a stick, but don't have a lot of trans experience (or funds for that matter) to do it. Also, if I stick with the auto, what are some things to let it keep up with the engine. Thanks in advance.
Tranny ID
Heres a site that'll help.
http://www.nastyz28.com/transid.html
BTW, yank the 305, plop in a 350 and enjoy the extra 45 cubes and the plethora of aftermarket stuff that goes with the bigger block. JMHO
Mike P
Mike P
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
if the tranny is original to the car, it is a 700r4 no questions asked cuz thats the only auto availible since 1984, in these cars, untill they brought out the 4l60e in the 4th gens
Car: Kitt
Engine: Classified
Hey thanks. Is there any way to tell if it's a posi? So, the 700r4 is a good trans? Also, I am planning on getting a 350 in the future though! After I get the interior and exterior fixed up. Would my current trans stand up to much more power? Should I keep my current trans and get a better stall converter?? What other ways are there to build up a trans for better performance?? I know so many questions, but I am trying to learn all I can. Thanks!!
Someone is going to tell you....
Someone is going to tell you to pull the cover and check the gears, and he would be 100% right. In the mean time you could check the code stamped on the FRONT of the RIGHT SIDE axle tube, about 3" from the carrier to cipher which gears came in that rear, ORIGINALLY. If you are POSITIVE that the rear is original you can check the code against those listed in the Haynes or Chilton books, or post them here.
unknown_host
Aftermarket Product Review
59
Sep 3, 2001 10:59 PM
sharky55
Aug 2, 2001 04:17 PM
scottmoyer
Jun 12, 2001 02:45 PM
