u-joint question
Old Aug 4, 2002 | 10:54 PM
RJR99SS's Avatar
u-joint question
i noticed that my u-joints are held in place with this odd plastic stuff. i know i have to heat it up to burn this out, then remove the joint. but my question is...how do i reinstall the new one?
well an aftermarket u-joint just come with clips or something i can use instead?
Old Aug 4, 2002 | 11:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The molded plastic retainer is factory installed. Using a simple propane torch is all that's required to melt it out so you can remove the u-joint.
The new replacement u-joint will come with metal retainer clips to hold it in. There's no way to reseal it with plastic.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
