flywheel!!!!!!!!!!
Old Aug 5, 2002 | 11:16 AM
Tb-Y?'s Avatar
Car: 91 rs/94z 28
Engine: 305tbi/350LT1
Transmission: 5spd/A4
flywheel!!!!!!!!!!
hey, im in need of a friggin flywheel, ive looked everywhere around here and the best i can find is $240 from napa ... my transmisson and all that crap is junk now so im puttin in a t5, and need a flywheel bad, so if any of yall know where i can get one, or have one id appreciate it...
flywheel needs to be
Outside diameter is 12 3/4" for years 1986-up. Crank Flange bolt pattern: 3.00"; clutch dia.: 10.4", 11"; starter ring gear teeth: 153. Lightweight nodular iron flyweel. Weighs approximately 16 pounds. For one-piece crank seal.
Old Aug 5, 2002 | 12:26 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using the Hayes 30 lb Billet Flywheel.Not much cheaper, but a lot better than a stock one.Part# is 10-530 and it costs $229.95 from Summit. It's gotta be twice the mass of the cheesy stock flywheel, so it holds up a lot better to heat without warpage.
This same one should fit yours, it's 153 tooth, one piece rear main seal type.
-Rich-
Old Aug 5, 2002 | 03:01 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
give jegs or summit a call
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
