gears for track
Old Aug 10, 2002 | 02:49 PM
Cuno's Avatar
gears for track
ok, what does everyone recommend for rear gearing at the track. I am swapping out my 700R4 to TH350 and wil be replacing rear gears(2.73) and need to know which gears would work best. Considering either 3.73 or 4.10. Should I consider steeper or lower? This vehicle will almost never be driven daily. Every once in a while will drive in town for fun.
What brands do you suggest? What should I stay away from?
Old Aug 10, 2002 | 10:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What size are the tires? What rpm are you shifting at?
You'll need to know these to determine the best gearing. You want to be at red line just before the finish line.
Assuming you'll have 26" tall tires, 5500 rpm shift points don't need as much gear as 6500 rpm shift points.
Since you're still using the 10 bolt, there are only a couple of choices. 3.73, 4.10/4.11 and 4.56 are your deepest gears. Anything below 3.73 is a street gear.
morrow
Jan 13, 2024 12:29 PM
fasteddi
Sep 10, 2015 09:32 AM
GouldyGTR
Sep 7, 2015 09:05 PM
Amillionoh7
Sep 5, 2015 11:44 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
