88 TA 7.5 to 7 5/8 gear swap.
Old Aug 10, 2002 | 05:00 PM
Bullseye's Avatar
Question for all gear heads. Today I bought an s-10 rear end with 3.42's for 10$. On the ring gear it is designated 7 5/8 and I was wondering if I can install the s-10 pinion, ring, and carrier into my 88 TA? I am sure this question has been asked before but I could not find it in the forum. Thank you. Jeff P.
Old Aug 10, 2002 | 05:26 PM
ede's Avatar
ede
if it came from a 10 bolt and it's going i na 10 bolt you can
Old Aug 10, 2002 | 05:42 PM
Bullseye's Avatar
Thanks for the reply. I just wanted to make sure before I ordered bearings for it.
Old Aug 10, 2002 | 06:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's no difference between a "7.5" and a "7.625" rear end. I have no clue how that rumor got started, it's on the list of rumors I would squish if i could.
They're the same thing. If your F car has the 7.6" rear, it will go in. You will need a set of pinion bearings, a crush sleeve, and an assortment of shims (although every one of these rears I have ever taken apart had a .035" shim, it's still a good idea to have an assortment on hand just in case) so buy a gear install kit from Ratech. Ignore teh comment in some other post about that all it is is a bunch of washers, that's what it's supposed to be.
GTAman
Jul 3, 2024 07:29 PM
F-body driver
Mar 6, 2023 11:44 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
