rear end growls...
Old Aug 10, 2002 | 10:19 PM
Akshay's Avatar
rear end growls...
When I let off the gas pedal, my car's rear end growls.
This only happens when I drive city speed limits (~50mph).
Akshay
1989 Camaro RS T-5
Old Aug 11, 2002 | 07:35 AM
ede's Avatar
ede
have you tried looking at it yet? i'd pull the carrier and pinion and check the bearings.
Old Aug 11, 2002 | 08:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Also check the pinion nut that holds the driveshaft yoke on, if it's loose it will make it do that.
Old Aug 11, 2002 | 01:21 PM
Akshay's Avatar
sorry guys, I meant my rear end howls......not growls.
Akshay
Old Aug 11, 2002 | 02:46 PM
4L60bliss's Avatar
"howl" or "whine" is usually a gear problem. "groan" or "grinding" is usually a bearing, but depending on how the bearing failed, it can make any of the above noises.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
