Tail shaft has movement
Old Aug 11, 2002 | 09:22 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I was replacing the output shaft seal in my 700-R4 and watched the shaft move when I was prying out the seal. I checked it out and there is about 1-2/16ths of play in the shaft. Is there a bad bearing or something in there or is it supposed to do that?? Is this the cause of the seal failure or is it the driveshaft out of balance?
Thanx
Old Aug 11, 2002 | 09:26 PM
4L60bliss's Avatar
You mean the output shaft has movement? Thats normal when the driveshaft is not installed. Its the driveshaft yoke riding on the tailhousing bushing that keeps it from moving. however, if that bushing is worn out, then yes, that will cause the seal to leak.
3rdgenparts
May 21, 2016 11:50 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
