Crap!!!!!! I didnt hear the TC click 3 times!!!!!
Old Aug 8, 2002 | 06:40 PM
JucinGTA's Avatar
Sh*t!!!!!! I didnt hear the TC click 3 times!!!!!
K I swear I thought it was in all the way, and then I tightend the trans to the Block and it was really bad, but didnt think anything of it(dumbass) Well right when I tighten them all, I check the T/C and it was impossible to move, so I ubolted it and found out I didnt have it in all the way!!! Do you think I could have fugged something up?
Old Aug 9, 2002 | 09:04 AM
JucinGTA's Avatar
ttt
Old Aug 9, 2002 | 06:41 PM
Jay 727's Avatar
The magic eight ball says.....................
You could have cracked the bellhousing part of the case. You could have bent the flexplate. You could have ......whats the point. If you want to know if you damaged anything either take it all apart and inspect everything or run it and see if anything goes wrong. I'd say the most likely part to break would be the case.
Old Aug 11, 2002 | 01:51 PM
4L60bliss's Avatar
I highly doubt the case is cracked. The weak point is the pump rotor. If anyting broke, it will be the pump rotor and hope no damage has been done to the pump body or cover. Your best bet would be to take it back out and look in behind the seal and see if the two "tangs" are still in place.
Old Aug 11, 2002 | 09:42 PM
Nordbert's Avatar
It is possible to bend the rotor without the drive lugs breaking
off. Measure from flexplate pad to rear of block and make sure the converter is in the bellhousing about .250" deeper than that.
Jae992
Aug 27, 2015 09:07 AM
B_Dubya
Aug 26, 2015 05:09 PM
db057
Aug 22, 2015 08:17 PM
Linson
Aug 21, 2015 02:12 PM
