leaking transmission fluid....
Old Aug 14, 2002 | 08:20 PM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
hi, my transmission is sitting on a jack under my car with no engine attached to it. to remove it from the engine i pushed the torque converter back into the tranny. the next day there was fluid all over my garage floor. where did it leak out of? did i break some kind of gasket when i pushed it back? what do i do to make it stop leaking when the engine is installed? or better yet, how do i put more fluid in??
Old Aug 15, 2002 | 06:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably came out the fill tube hole...
Old Aug 17, 2002 | 02:02 PM
Psyte's Avatar
gasket
is there a gasket or seal that i possibly broke between the torque converter and the transmission?
Old Aug 17, 2002 | 09:28 PM
4L60bliss's Avatar
Can you see exactly where the fluid is coming from? I wonder if maybe the pump bushing is worn out, and the torque converter is "sagging" from not being supported by the flexplate and is distorting the seal. Just a wild guess, if it is coming from the pump cover. Try and take a good look at where its coming from. You didn't accidently punch a hole in the pan w/ the jack, did you? Gotta ask these things....
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
tgp1990
Sep 4, 2015 06:24 AM
jtwoods4
Sep 3, 2015 05:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
