rear end....
Old Aug 15, 2002 | 01:10 AM
Opha's Avatar
rear end....
just wondering what was the best rear end gm made that will fit? and im not into the ford 9'' at all, i want to keep it all gm. just trying to find the strongest rear end so i wont have to worry about breaking much when i get my new engine.
and one supid and quick ?...what is the diff between a posie and differental....and what does each do?
some things r just worth asking.... thanks!
Old Aug 15, 2002 | 06:05 AM
ede's Avatar
ede
12 bolt from moser
Old Aug 28, 2002 | 10:13 AM
johnnyformula's Avatar
the differential is the set of gears that converts motion from the driveshaft to the two rear wheels (it's the big thing in between the rear axles). a 'posi' is a TYPE of differential. with a normal differential, if one rear wheel is spinning, you won't move forward. with a posi (positraction, or limited-slip), the differential transfers power to the wheel with the most traction, so you can still move if one rear tire is spinning. if you want the strongest, most enthusiasts swear by a 12-bolt moser, but it's not cheap. the 9-bolt Borg Warner was stock on some 3rd gens. it's not quite as strong as the 12-bolt, but is a lot less expensive.
Old Aug 28, 2002 | 12:38 PM
Opha's Avatar
thanks alot for clearing that up and for the info.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
