difficulty swaping in 5-speed
Old Aug 18, 2002 | 02:43 AM
Don_89Iroc's Avatar
Anyone who had swaped a T-5 in there 350 tpi, how difficult is it? i hope to have it done in a days time, cause i need my car, i belive i have every thing i need, i heard the hardest part is putting in the clutch petal, is there any thing you guys can tell me about that to save me some trouble, thanks in advance, any advice will help me, -Don
Old Aug 18, 2002 | 07:41 AM
4L60bliss's Avatar
If you have never done one, I think you might want to allot yourself more than one day.
Old Aug 19, 2002 | 07:31 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
You will need more than one day. Two minimum. I'm in the process of swapping a T-5 into my car right now. I bought the car no engine or trans. I had to swap pedals in my car and the one he was keeping. He wanted the auto I wanted the manual. The best advice I can give is to drop the column down to get to the top left nut. Also it helps to have someone to slightly pull on the brake booster to help disengage the pedal assembly from the studs. Good luck!
Old Aug 20, 2002 | 08:06 PM
Speedemon171's Avatar
Car: Camaro
Engine: 350 SBC
Transmission: Five speed
there are a few things you have to do:
1. cut hole in floor for shifter
2. cut hole in firewall for clutch slave cylinder (might want to make a template from a car with a 5-speed)
3. put in pedals (what a b!tch that was)
4.you have to rig a special wire for the reverse lights
jhawkeye
May 25, 2022 06:33 PM
RedLeader289
Jan 22, 2016 03:05 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
john204481
Sep 7, 2015 03:22 PM
Fox118
Sep 1, 2015 04:07 PM
