Question about 460LE
Old Aug 20, 2002 | 08:35 PM
worldofool's Avatar
Does anybody make a manual non-electronic valve body for the 460LE. I'm having problems with the electronic part of the transmission.
Thanx
Old Aug 20, 2002 | 08:46 PM
4L60bliss's Avatar
Yup, its called a "700R-4" The only way to ditch the electronic controls is to ditch the electronic trans. 700R-4 is the non-electric version of the 4L60-E.
The case is specially designed to work w/ the 4L60-E specific valvebody, which is based on electronic contol. It would be very difficult if not impossible to take that electronic control away. There are no provisions for a governer, no provisions for a TV Cable, etc... Not to mention, because of the elctronic controls, fluid is routed differently for many of the circuits. If anybody could create such a thing, I'm sure it would be cheaper to fix what ails your transmission, then to purchase one of these.
Old Aug 21, 2002 | 03:52 AM
transfixleo's Avatar
While you can get a Manual shift setup, how about the idea of fixing this one?
Old Aug 21, 2002 | 05:50 AM
4L60bliss's Avatar
I have seen the "manual shift" setups, but the ones I have seen were still electronic. He was looking for a non-electronic.
Old Aug 23, 2002 | 11:48 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Seems like it would be a pain in the a$$ to switch from the electronic controls to the non-electronic controls....
Old Aug 24, 2002 | 11:22 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
It can't be done as the hard parts are the same, the valve body's are different. The passages in the case are different as well. JET has boxes to run electronic tranny's without a PCM (As with a carb or TPI or a 93 LT1) On the pricey side though, but you can control the shift points and firmness w/o getting your hands dirty.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
